Radial Menus When Using M&K
  • Radial Menus When Using M&K
    I'm using my mouse to hover over the radial menu and left-click (assigned as "Apply") to activate a segment. However, simply hovering over a segment with my mouse also selects it.
    Is there a way to configure the radial menu so that a segment only activates when I left-click (Apply), rather than being selected automatically when I hover over it with my mouse??
    I noticed on the ReWASD radial menu help page (https://help.rewasd.com/mapping-features/radial-menu.html) it states:
    There are two options to apply the radial menu:
    Option 1: Using the "Apply" Button:
    Open the Radial Menu.
    Choose the desired sector.
    Press the button mapped with the "Apply" action in your Radial Menu Shift.
    Option 2: Leaving the Radial Menu:
    Select a sector.
    Exit the Radial Menu shift.
    When exiting the Shift, mapping starts on the active sector.
    The problem is, is that I want to only use option 1, but hovering over the segments with my mouse also selects the radial menu, so essentially I have 2 methods of applying the radial menu, and cant disable option 2
