Cycling
  • Cycling
    I want to be able to cycle through multiple commands by pressing a single button multiple times. Example: cycle through available weapons in a FPS by pushing the button multiple times. Is this possible?
    Hello! reWASD allows you to add several mapping to a single one button. With each new press, the new mapping will be emulated. To do so, you need to go to Key Combo, add action #1 + break + action #2 and so on. First press = action #1, second press = action# 2, third press = action #1. If each weapon in the game has a unique combo or key to activate it, the breaks will help. If not, could you please specify how to switch weapons using keyboard and mouse? Will try to extrapolate it to the controller + reWASD.
