I am unable to continue using reWASD because this pops up every time I boot my pc. I've tried rebooting, but I'm not sure what is causing this. I attempted to uninstall it to get a clean install, I've tried downloading and installing a new version, and it continues to block me by asking me to restart my pc. The installed version is 3.2.0.0674.
reWASD requiring reboot, but unable to comply
Please launch regedit.exe app as Administrator. Just type it in task bar search box to open.
Here, you will need to go to 3 directories:
1. HKEY_LOCAL_MACHINE\\SOFTWARE\\WOW6432Node\\Disc Soft\\reWASD\\
2. HKEY_LOCAL_MACHINE\\SOFTWARE\\Disc Soft\\reWASD\\
3. HKEY_CURRENT_USER\\Software\\Disc Soft\\reWASD\\Config\\
Two first ones may include "RebootFlag" item. If yes, please delete it.
The third directory may include "RebootRequired" item. It should be removed too.
After you find the needed flags and remove them, please try to launch the app again.
The reWASD320-0681.exe build version is available, so please download the latest one for further software installing.
