I setup an xbox elite controller with mouse controls and it works great. Except when I try to start certain programs. When I click programs that open the "Do you want to allow this app to make changes to your device?" I can no longer use the controller to move. I need to use the pc mouse to select yes, then I can use the controller again. Is there a way to continue to use the controller to select yes so I don't need to switch between input devices?
Loss Of Control When Selecting Programs
Well... Yes, we know about this problem and unfortunately, don't have an elegant solution at the moment. Locally you can disable UAC at all (in case it's convenient for you) or run a required program as administrator as default (some adjustment - right mouse click on the software icon - Properties - Advanced - run as Administrator).Don't worry! Be Happy!
