I play World of Warcraft with the addon ConsolePort. This addon it was design to work with WoWMapper and WoWMapper have a mapping keys that ReWASD dosn't have and is the D-Pad. The arrows Up,Down,Left,Right dosn't work like D-Pad. I will love to have D-Pad mapping in ReWASD since Im using an Xbox Elite controller which is usless with WoWMapper and useless as well with the current version of ReWASD, unless you guys add D-Pad mapping. Thanks.
D-Pad mapping
ConsolePort Addon use WoWmapper app to map the controller. In WoWmapper keybinding options there a D-Pad keys Up,Down,Left,Right that is use in game by ConsolePort http://prntscr.com/lg4c4p Without these D-pad keys I can't use ReWASD with ConsolePort.
Hello!Originally Posted by WarnerDethy View PostHi,
Can we take the File aid mapping with the copybook to a note pad.
I mean can we NDM the mapping to a note pad in text format.
Please advise.....
Thanks,
Sujit
Your config files are stored here: C:\Users\Public\Documents\reWASD\Profiles
You can pick any *.rewasd file and try to open it in Notepad.
You will see the JSON file with all settings and mappings you have made in reWASD. It is pretty tricky to read but if you want you can try it.
If you make some inappropriate changes inside the file and open it in reWASD again, all incorrect changes will be removed.
