reWASD does not open, !
  • reWASD does not open, !
    I have windows 8, and i intalled reWASD
    icon show up in option bar under the small triangle
    I connect my xbox one controller throuth bluetooth, it detect it
    then i click on open reWASD, it show up in Task manager 3 second then go away
    Nothing is happening, already try to uninstall and re-install, problem still here.
    Does reWASD open without the controller connected? Did you open via Admin? Does reWASD open if the controller connected via cable?
