Quick addition; I removed the 4th device on the list(the faded out Controller) and while I had to re-pair my xbox one controller to the wireless adapter, it didn't seem to fix anything. Except that the removed entry didn't reappear. Also when a ReWasd config is active I do see an additional controller icon that says "Virtual Xbox 360 for reWASD", just to clarify.
Virtual 360 controller stuck as Player 2
Thank you for the screen and info. Yes, seems that everything should be OK.
There's only one thing that comes to mind: you have the out-dated Windows 10 version. The current active version is 1809 (https://www.microsoft.com/en-us/soft...load/windows10). Maybe, with system update and reboot after applysing the virtual controller in reWASD, other games will also see this device.
