Use controller to play fps , on PS4 or Xbox are always 1:2; on pc there is not the setting ,Can i set it in Rewasd?
Can I set Different Horizontal Sensitivity and Vertical Sensitivity?
There is no such feature to adjust the horizontal sensitivity apart of vertical as adjustment applies to the whole stick. As one of the solution, you may try to set different stick response options (including the custom one) according to your needs - http://recordit.co/m0D8CJdYcz. It might help.Don't worry! Be Happy!
Only one has passed since the end of March, and the next is coming pretty soon.Originally Posted by ventus View Post
Several versions have passed.when will this feature be released?
Unfortunately, the new release won't include this functionality still as it is already over-packed with other planned features. I can't say you the exact date but hope to deliver it this summer.
Steps are:
1. First, go to the Stick (let say the Right one) advanced settings, and move all the zones except High zone - http://joxi.net/KAxo0JeuZRkO52.
Make the high zone the only zone that will be on the stick (except deadzone, the grey one).
2. Shortcuts. As an example, I added right stick up + high zone, add a mapping Mouse Up, Right Stick down + high zone, add a mapping Mouse Down - http://joxi.net/L21zgGLsRL41lA.
Using the mouse sensitivity (2) and the mouse virtual setting (1) you may set mouse reacting quicker or lower vertically - http://joxi.net/nAyxlJzFg310g2.
So moving the stick up or down the sensitivity changes when the stick in high zone position (you may set also different zones depending on your needs).
3. Then add mouse left and right to the right stick in the main config, and you will see "use global mouse sensitivity"- http://joxi.net/p279p48hK5Bqar
Change it to the sensitivity you need, make it bigger so it would react quicker horizontally.
Please, let us know if any questions remain.Don't worry! Be Happy!
Thanks! But I have some problems.Originally Posted by Star-Lord View PostSteps are:
I set everything as you showed and The speed in both directions is really different. But the speed in the vertical direction is uniform, It always be the same, Did I do something wrong?
The vertical direction sensitivity changes with virtual mouse settings in virtual devices. I made footage for you - http://files.disc-soft.com/filer/shared/1566281472/318/. As you may see mouse movements are faster or slower depending on the slider position in the virtual devices option. You may try to change the zone to medium in the stick advanced settings and shortcuts. In this case, the mouse movement changes when a stick passes a medium zone. Perhaps it will be more observably. Also, try to change the mouse acceleration to speed up your mouse in a high zone.
Please check that you have latest 5.1.0 version installed, the build version reWASD510-1302.exe.
Is the problem happening in the game (which game?) or like desktop using?Don't worry! Be Happy!
Ah, I understand you. But I mean when I push the stick, the speed of mouse should be related to the distance I push the stick(Just like only set stick to mouse without other settings), If I use the high-zone way, no matter how much I push the stick, the speed won't change. For example I push 0.5cm, mouse is 5cm/s ,when I push 1cm, mouse should be 10cm/s,but the high-zone solution is still 5cm/s. Just like push a button not a stick, the speed should change when you push the stick different distance. the change should be linear, If I set a midium zone, it will just have 2 mutations.Originally Posted by Star-Lord View PostHello,
