I play Destiny 2 on PC. My goal is to be able to use a controller with my left hand (for movement) and a mouse with my right hand (for aiming). I'm managing to do this to some extent, but I'm experiencing two problems:
1. How can I set up the analog stick of my controller in reWASD so that it allows more than just 8 different movement directions? Currently, there are only 8 different zones the analog stick could be in:
2. When I try to walk, rather than run, I tilt the analog stick only slightly. This allows it to rest in the "L-Stick Low" zone, as reWASD calls it. The walk works fine, but while I'm walking my mouse input will be disabled. I think this has to do with the fact that Destiny does not allow simultaneous input from both controller and mouse - it's as if the controller is identifying itself as a controller when I walk, but a keyboard when I run. I need it to identify as a keyboard always. How do I do this?
