does anyone own or know if rewasd has support for the razer raiju ultimate thanks in advance
controller support for razer raiju ultimate
Usually, Razer controllers are detected as Xbox One in the system and so are visible in reWASD. However, you won't be able to work with additional buttons that are physically present on Razer. Razer paddles are not visible to the system as separate controls. You can use reWASD with this device, but you won't be able to assign unique actions to the additional buttons. However, if you need to add more actions to your controller, it is easy with reWASD using Activators (double-tap, triple-tap, long-press and others), Shift mode and Shortcuts.
