It’s been a while, but finally here we are — ready to surprise you once again
Let’s take a brief look on all the changes that come to reWASD 5.7:
Please visit Desktop Overlay settings to adjust which parts of the Overlay you want to see and how you want them to be shown. Also, one small note: our Overlay perfectly works for the games in windowed mode but may not be shown if you are using the full-screen mode. Please let us know if we should go further with this functionality. Any feedback is appreciated as always.
The list of fixes goes next:
And finally, important note!
After the update, you will need to re-enter your serial number once again. We are sorry for this inconvenience, it was done for the best. Your serial key is stored in your personal account.
- Check reWASD notifications, test the virtual gamepad and use hotkey to show mappings during the game with our Desktop Overlay
- Remap NVIDIA SHIELD 2015 & 2017 controllers
- Select any nodes in a combo and copy, paste or remove them together
- Create longer combos without any restrictions
- Set up to 1-minute pause between Turbo presses
- Hide the tray agent if needed without losing the functionality linked to it before
- Use Nintendo Home LED to notify about the connected device, changed Slot or Shift, Low battery
- Move your mouse cursor above the physical button to see the whole list of mappings
- Feel free to use reWASD with the French localization
- Fixed: The agent crashes trying to apply a config with some antivirus apps installed in the system
- Fixed: Several fast clicks on Apply button for the config with a virtual controller may create duplicate gamepads
- Fixed: Occasionally, the Left Stick down mapping is emulated after several fast movements of the Right Stick
- Fixed: The config that includes too many mappings may be applied with some non-working actions
- Fixed: Unmapped gyroscope inside the Shift doesn’t cancel inherited mappings from the Main configuration
- Fixed: Tray Agent’s menu closes after opening if the graphical tablet is connected
 Desktop Overlay. NVIDIA SHIELD 2015 & 2017. Nintendo Home LED. And more!
