Hello, I've been testing the trial version for 3 days now and while using the software I noticed a few things that I would like to talk about here...
First of all, my Roccat Tycon mouse has a joystick on the side and is recognized in Windows as a "HID-compliant game controller". Although I disabled them, they still appear in reWASD and it says "Your device is not supported. Want reWASD to work with it? Request it now."
My question is, could you add an option to hide devices? Either individually or globally via the settings? Like "Hide all unsupported devices"?
Next I noticed that "Vibrate to find this gamepad" does not work. No matter if with the Xbox One Controller or with the Elite Controller. An idea why that might be? Vibrations in the games are working with reWASD. (win7 x64)
Then I have a general question: I don't make any profiles or configs for various games but rather use only 2 to 3 different configs for all games. So the mappings are always the same. There are always 2 controllers connected and both use the same config. At the moment I have to select controller 1, then the "game" then the config then the Apply... and then the same for controller 2...
Isn't there a better or faster solution? I have seen that the configs are saved as *.rewasd. But if you start it the config is supposed to be imported and not applied to the controller. Is there a way to apply the profile directly to the controllers when starting the software?
So my question about this: What is the fastest way to get a config on 2 controllers at the same time?
Thanks for reading and sorry for my bad English
