Hello reWASD team, loving the software to play Valorant. I am a Flick Stick user and I have a lot of experience using it on JoyShockMapper so I'd like to give a few suggestions and feedback to make it better for reWASD as not all options are working correctly and some controllers do not get the same benefits as others.
Another differene between the 2 controller is when rotating the right stick, the DualSense is very smooth on camera rotation with Flick Stick but the Pro Controller has very noticeable jitter when turning around, JoyShockMapper also experiences this and it could be because of the resolution of the stick is different than the DualSense but with reWASD it's more jarring. If you could look into this and compare both controllers you may see how this is pretty unfortunate for Pro Controller users.
That's all I have to share with you today. If anything else is discovered I will report back to you, regardless of these issues setting up Flick Stick with reWASD doesn't take very long which has been very nice, I do hope the duration setting does get fixed soon as it's very bad on my eyes using it without it. I hope this has helped and take care.
					- Flick Stick's "Duration" setting does not work.
- Default "Threshold" of 90% is not set when first enabling Flick Stick.
- From my testing going from Sony DualSense to Nintendo Pro Controller has some major differences
