Hi, I think this is a fantastic product by the way. It does, however, suffer from the same ailment that many previous softwares have suffered and that being that here are only 4 keys directions for the joystick.
PC and WASD movement is notoriously rigid but people still get by with enjoyable gameplay and no company has desired to R&D a product that allows more degrees of movement because WASD is sufficient, BUT the reason it's sufficient isn't that it provides for cardinal directions of movement, it's that it allows for 8 directions of movement. Each lateral key is combined with each forward/backward key to make a 4th direction.
Please, if you've gotta heart, I love PC gaming, I hate the keyboard for movement but 4 directions is not enough, there needs to be 8 quadrants of 45 degrees. Gameplay will be fluid and I guarantee people will be happier.
Thanks for the consideration.
PS I bought the $20 version this shits so good but 4 movements playing FPS games are making me insane.
