tl;dr: reWASD software made Synapse (Razer software) unable to recognise my Orbweaver, if you got trouble with Synapse and got reWASD (or maybe something like it), try to temporarily disable it while you get razer synapse to work, then enable it again, worked for me.
So much trouble, but so easy solution.
3 weeks ago I couldn't get into Razer Synapse and change settings for my Orbweaver, Synapse didn't seem to detect the Orbweaver, even though it showed up on Device Manager, and the default buttons worked. But what's the point with an Orbweaver if the buttons can't be reprogrammed.
So I tried everything, was in touch with support (they were nice and tried their best), but I just couldn't get the Orbweaver to be seen by Synapse. I installed and reinstalled several times until I gave up, took to many hours.
But I like my Orbweaver, I got frustrated over the finger gymnastics I had to do to play certain games, so I had to do a retry.
So I uninstalled everything, reinstalled, didn't work. Tried a bit harder, went into the registry and picked out everything with Razer in it and did a thorough search, finally everything gone, followed the instructions on how to do a clean install, disable virus software, defender and firewall, still didn't work. Frustrating.
But then I remembered I downloaded reWASD, because I wanted to properly reprogram my Xbox Elite controller, I thought maybe if I turn that off synapse will work. And loathe and behold, it did, Finally!
Happy ending.
Happy ending.
