Can break be used to do the following for example if I map F and 1 onto the same button. and marco them like a if-else loop
If F available activate F otherwise go to 1 all with one button press then it goes back the beginning after the press (F and 1 are conditional buttons that only become active on certain condition).
This actually saves us button space . For example I can map multiple conditional or cooldown action onto 1 button using logic. I know BNS tires to do this with simple mode but it kind of limited
