After updating to version 5.0 it told me that I needed to install some new drivers which I did. During the installation of said drivers all of my other USB devices (keyboard, mouse and HOTAS) started turning off then on again and then it asked me to reboot my PC. After reboot I immediately noticed a problem with SteamVR. When SteamVR launches I get absolutely no input from either my HOTAS or Xbox controller. After fiddling around I found that in Steam app if I go to Settings>Controller then click on any controller related menu and then just close it without applying any settings I get my input back. Same if I launch Big Picture.
This started to happen as soon as I updated to version 5.0.
So my question is how do I completely remove all traces of Rewasd 5.0 including those drivers that caused all of my USB devices to freak out during the installation? If i just uninstall it via the Control Panel I still get no input in SteamVR.
