altering output of very highly sensitve analog sticks
  • #16
    ok, while I am at it, can support be added for my OG xbox, GC and retrolink n64 controllers? they are all standard dinput
    • #17
      and I got a decent (best so far) xinput going with this config (reversed y is not permenent... xinput and dinput have them opposite each other)Click image for larger version
      • #18
        Your setup is pretty interesting. Hope this one will suit you best!
        We are working on adding more controllers to reWASD. I won't promise you the fast update but hope you will be able to use those gamepads in our app in a while
        • #19
          medievil Did you ever good stick settings that matched native hardware feel? I tried the last ones you posted which I think helped but is hard to tell.. Thanks!
