So im trying to map Left trigger to mouse button or keyboard after i set it up in rewasd it doesnt do anything ingame and i cant figure out how to make it work
Need Help
How do you map the LT to the keyboard (mouse)? Check this screenshot - https://recordit.co/O7Hejwn7cm. As you can see LT works while "Q" pressing (as an example). What is happening in the game? In case the game sees the keyboard (mouse), use unmap to mute the keyboard input and use only trigger one.
Let us know if the problem remains.Don't worry! Be Happy!
hey thats exactly how im setting it up but when i press q or any other button i try to map it to it doesnt make the z axis moveOriginally Posted by Star-Lord View PostHello,
