Hello, i have rewasd but i have not use it much yet. I am new at its use.
I have a question. I would like to use rewasd to map the joystick of a ps4 controller (used on a pc) to keystrokes.
A joystick can be moved in 4 directions and usually a soft movement of the joystick in a direction, allow slower movements in games compared to instead hard movments of the same joystick to a direction. Would I be able to emulate that with keyboards , using rewasd ?
It would be like assigning two keystrokes to for example the move of the joystick up.
A soft movement of hte joystick up , would output a letter (for example z)
A hard movement of the jpystick up, would output another letter (for example d)
Would that be possible ?
Thanks!
Thanks!
