Mouse combo turbo
  • Mouse combo turbo
    Left mouse button in combo doesn't work with turbo unless there is a pause placed between press and release.
    Thank you for the report.
    Some games may ignore the input of key sequences if the elements of a sequence don’t have a pause between them.
    Adding the pause will allow recognizing this input in the game.
    You may check the combo work with joy.cpl and your eye can't catch those button presses we recommend adding\ increasing the pause (at least 20 ms) inside the combo elements - [link expired]
