assign a combo sequence from controller to a keyboard key?
  • assign a combo sequence from controller to a keyboard key?
    Hi ive been looking at different programs like this one for a few days trying to decide on which one to buy. as of right now the main purpose i am looking at the programs is to get a combonation of controller presses into 1 click either by assigning them to 1 button on the controller or what would be better is to assign them to a keyboard key that isnt being used by the game already. i tried to use the free trial but i didnt see exactly how to assign it to the keyboard key and when i attempted it with the controller it was buggy and kept doing functions of the game already assigned to that button and very slowly. if i can get this to work with an unused keyboard key that would be perfect and i will likely buy it today. is this possible? what i need to do is have it click right stick or R3 then right trigger then A from one button press each time as fast as possible.
    Thank you for your question.
    As I understood you need a gamepad controls combo to make using a keyboard what is emulated as a gamepad. Please check the video I made for you to see the steps and controls sequence - https://streamable.com/hbcmi.
    As you can see the keyboard is emulated as a controller and the "1" contains requested combo. I added a big delay between controls that you could see how it works, usually, 20-30 ms is enough for comfortable combo triggering.
      ok i see tyvm i will be trying this out which version allows the macros to be assigned the $9 or the higher one
        Please, use the 5.2.2 version which the latest one. Also, note that buying the feature you get the license (Lifetime) free.
          yea is it the $9 one or $15.99
            The $9 is a feature only where license included. The $15.99 is a Full Pack, all 4 features included + license key with lifetime option.
              can i get a 2nd license for my 2nd laptop for less than 15.99? i bought the first one but id lie 2 pc installations
                I sent you PM message in order to your last question. Check your forum messages.
