I am trying to adjust the mouse sensitivity settings. After making the changes and saving, they are not staying saved and revert back to the defaults. I need the mouse to be more responsive and can't get it to work.
Mouse setings....
Are you trying to adjust mouse mapped to stick, right?
It should be done here:
After you change settings, please ensure that you have clicked the Apply button (1) in order to get changes work.
Or do you play via remote play and you need to adjust mouse sensitivity that acts like controller stick in the game?
Great to know! I also could provide more information regarding advanced mouse settings:
1. Tutorial about stick deflection- https://help.rewasd.com/basic-functi...-settings.html
2. Settings of Smoothing, Noise filter, and Sensitivity adjusting is here https://help.rewasd.com/basic-functi...-settings.html
3. Option to change the mouse sensitivity for Shift Modifier 2: https://recordit.co/X8L6GK4zU4 (usually for better aiming performance).
And of course mouse DPI.
Also, check this video - https://www.youtube.com/watch?v=1etu...ature=youtu.be It' advanced mouse settings for Fortnite playing, but you can also use it for your settings.Don't worry! Be Happy!
