I have an issue where upon Windows boot up, rewasd turns on my virtual controllers automatically. When I run the Cemu emulator, it recognises both virtual controllers as Controller 3 and Controller 4. If I turn remap off for both controllers, then turn each back on again, one by one , they will be controllers 1 and 2, which what I want. If I turn on remap for both at the same time using the shortcut in the system tray, it makes them Controllers 3 and 4 again.
If you have a solution for this where upon boot up they become Controller 1 and 2, instead of 3 and 4, it would be great. Otherwise, is it possible to have a keyboard shortcut to turn remap on for each controller separately?
Thanks,
Branded.
Thanks,
Branded.
