(X-Box360 on PC) I need a macro that emulates pressing the A button, 1 sec pause, A button, 1 sec pause, Num -, pause 20, rinse and repeat X times. I want to activate this sequence by Hitting M on my KB.
FF14 help
This topic is closed.
Thank you for your question.
I think you may enter the following sequences - https://prnt.sc/ru4lh3. Not sure about the delay after the Numpad (20 ms, I guess). And to repeat it X times, please set turbo to the mapped button - https://prnt.sc/ru4i4d. Please, make sure that RapidFire feature is active (3days trial is available).
So, it goes A down\up - > 1 sec delay - > A down\up - > 1 sec delay - > Nun button - > set pause.
Also, please specify about rinse? What did you mean?
Another variant if you need exactrepeats. In this case, you may add a certain number of iteration (like 7 for instance) in the combo directly - https://prnt.sc/ru539q. In this case, the combo will be triggered 7 times in a row.
