onscreen keyboard for chating ingame
  • onscreen keyboard for chating ingame
    Hello there. i bought rewasd and i love it. i cant find a way to use something like onscreen keyboard to write in chat game. for example i play ARK evolution evolved. when you press LB and option button a windows popup in game with the global chat of the map. in ps4 and xbox a onscreen keyboard appears and you write what you want with your controller. any idea to do it with my controller and rewasd?
    I assume that the game you mentioned has an embedded on-screen keyboard. So first, I would ask you to check the game you are playing at the moment: maybe there is a shortcut that enables it? Then, it should be mapped to some controller button.
    Also, there is another option. You can use the Windows on-screen keyboard, and it should work for any game.
    To enable it, choose a button (or a shortcut or an activator) in reWASD, go to Key Combo, Switch to Hold until release mode and add three keys: Win+Ctrl+O:
    Press Apply and try to launch this action to get a keyboard on your screen.
