Hey there, welcome back!
In your config, you have both keyboard mappings and virtual controller mappings. If keyboard ones work, then remap is on, and it seems that the only issue with a virtual controller detection. Seems that a game can't see this new device. I've checked this one (with Steam, and Discord is also working on my machine), and it works good, so it seems to be some local issue we are missing.
Some games and apps do not see the virtual controller at once, because they are locked with a physical one. The only thing that may work is to re-apply a config and restart all apps, tools and launchers that may do this. So, basically, you found the best solution — launching those tools manually (just can't understand why they interfere in your case). You have another option: try not to use a virtual controller (the only case why you need it is because of Turbo on a trigger in Shift 1, but you can change it and use mouse button click with Turbo). Can you try this option?
