So I'm in shift 2 when trigger is stuck, I must then activate shift 4 where normal keyboard and mouse are assigned back to me, then remove shift 4 so mapping is applied again?
According to testing, this sticky thing happens only between inputs switching (keyboard -> controller, controller -> keyboard). Only shift #4 does it. Shift #2 is about aiming it has the same mappings as the main layout (only some differences for R2, a bigger stick deflection, less sensitivity,etc.). So, it shouldn't be a problem with shift #2 unless some of the buttons aren't unmap.
