I'm using reWASD to map Keyboard + Mouse controls in Satisfactory to an Xbox 360 style controller so I can play comfortably on the couch. I have everything working great, however this game has a lot of menus! Right now the mouse movement is tied to the right stick, just like any other game with FPS style controls.
When in a menu however, it is much more intuitive to have the mouse movement on the left stick. To do this, I created a shift layer with this mapping, and bound the shift activation to an unused key ('M') with toggle turned on. This works alright, but it's annoying to have to manually toggle the layer on after opening a menu, and then manually toggle it off before closing the menu.
So what I want to do is automatically toggle the shift layer when I press a button that would open a menu (there are multiple, so I can't just tie it to one button). For example, say I have the X button mapped to the 'Q' key, which opens the build menu. It would be great if the X button could also trigger the 'M' key to activate the shift layer in addition to pressing 'Q'. I tried to do this with a macro or "key combo" but the shift layer was not activated. Checking in a text field, it DID type 'qm', but the shift layer is not activated.
Am I just doing something wrong? Is this not supported? (if not, it really should be).
I have purchased the reWASD complete pack so any and all features are available to me to make this happen.
