I'm new to this software I'm using it for my Steam Controller and this has probably been asked before but I wasn't able to find it.
Basically I would like to be able to hold the Back/select + A and have it switch Configs or profiles or whatever you call them lol.
example: while in-game use a shortcut to switch from Xbox 360 controller to Xbox 360+Mouse emulation then use a shortcut and switch to a WASD config.
(IDK if I should be saying Config, Profile, or Slot)
I guess while I'm asking, can the software currently emulate trackball style mouse where when I flick the pad it will keep rolling a bit?
Thanks guys!
Thanks guys!
