Hitting a precise joystick y value
  • Hitting a precise joystick y value
    If youre familiar with smash bros melee im trying to program a shield drop basically the stick needs to move to exactly -67.5% of its full value. normally this is done by hitting the notches but im using a ps4 controller which has no notches. is there a way to program a button to achieve this?
    Shield dropping is an advanced technique in all Super Smash Bros. games prior to Super Smash Bros. Ultimate, where it was removed. It involves dropping through a soft platform while shielding by...
    At the moment, there is no way to set the max deflection of a physical gamepad. The only way to achieve something like this is to make a set combos and map them to each direction, like the one I have here:
    Could you please try this workaround?
