Essentially I'm looking to do the inverse of a shortcut. I want to map Square+Circle+Cross to all one button, but when doing it in key combos, they are inputted with commas, as separate inputs. And in-game they are also done separately instead of one input. Is there a way to do this? Does this make sense?
Is there a way to map multiple inputs together to one button?
I think so but I’m not sure I’m doing it correctly. From my understanding, with shortcuts, you can map multiple buttons for a SINGLE input. Ex: pressing R2+L2 can be a shortcut for jump. I’m trying to do the upset where the jump button can input BOTH the R2+L2 not R2,L2. Is there there a way to do this or can be explained in a way I understand? The FAQ doesn’t help me much. Thanks
