USB Foot switch stopped working after installing reWASD
  • #16
    thank you so much!!!
    • #17
      any updates?
      • #18
        Hi there,
        Well, the pedals that we've ordered early were delivered yesterday and we've managed to test them already. The issue is confirmed, but the good news that the new reWASD version fixes the issue. The next release is planned to release in early November. So, stay tuned!
        • #19
          Hi there,
          MEGA-Awesome, you guys rock!
          Never regretted paying for this excellent piece of software but support like this is the cherry on the cake
          *** THANK YOU ***
          • #20
            Hi there,
            You're welcome and thank you for the kind words.
            • #21
              Is the iKKEGOL USB Double 2 Foot Switch Control Pedal Video Game Customized PC Keyboard Multimedia Key Free Drive HID among your test foot pedals. As I know that one is also effected. Before install rewasd footpedal worked. With it installed it did not work. Once I uninstalled rewasd the foot pedal started to work again.
              • #22
                Hello, rolesnevich
                I think they are similar devices, only VID\PID is different, therefore, the next version will fix with an issue with your device as well.
                • #23
                  any update on this update release ETA?
                  • #24
                    No certain date yet. But we are planning to release 5.6 update by the end of November.
                    • #25
                      Another footswitch that stops working:
                      http://www.pcsensor.com/foot-switch/...vice-p294.html
                      Is the 5.6 going to resolve the conflict in general or a special patch will be needed?
                      • #26
                        Hi there,
                        Hope it will work with the 5.6 as well.
                        • #27
                          Just for the record, this issue also occurs with the Logitech Racing Wheel G920. It's not that I want the g920 to be supported by Rewasd, it's that Rewasd is somehow blocking the G920 detection on the Logitech G Hub.
                          After uninstalling Rewasd, the G920 works perfectly. Hoping patch 5.6 fixes this device conflict as well.
                          See ya.
                          • #28
                            Hi there,
                            Hoping too.
                            Unfortunately, we don't have this specific device to test, but with driver fixes, it has to be working.
                            Thank you for your side note.
                            • #29
                              See ya.
                              Same problem here with the G920 steering Wheel. Logitech G Hub-Software does not recognize the steering wheel anymore. Games are working, but the force feedback is turned off. After uninstalling reWASD-Software everything works fine.
                              Tried to blacklist the steering wheel, diabled the game-service ... nothing but uninstalling reWASD and rebooting the complete system helps.
                              I count on you to remove this problem in the next release !
                              Thank you !
                              • #30
                                Stay tuned, we are planning to release the new version in December. Hope there won't be any issues with the next release.
