It looks like if you switch a shift mapping while a buttom is being held, the new shifted mapping does not register the key being held.
You basically need to release and press they key again.
Note: I have different actions for the same key in each mapping.
I want to perform the 1st mapped action, and 2nd mapped action once you switch mappings without the need to release and press the action key again.
Is there a known workaround for this behavior?
Thank you.
Thank you.
