I have similar problem like here in this post
I'm using a usb switch to connect mouse and keyboard to two computers. reWASD detects the switch as "USB2 Hub" and I can only select either mouse or keyboard at same time. It is not possible to select particular device. Additionally I have also a gaming keypad connected to the same switch.
I added the switch (HUB) as a mouse now and tring to add additional keys, but it is annoyng to add all the mapings manually. I want to use keyboard and mouse as a virtual controller. Is there a config ready to use?
The link from the linked post does not work anymore.
Thanks
Georg
Thanks
Georg
