Hello, I've been using ReWASD to change the joystick input to Mouse for first-person shooters. I lowered both the X and Y Vertical Axis Range to '1' so that I can have a comfortable range and follow players easily when they try to strafe side to side...
My problem is, my joystick seems to run into a "wall" at random and my joystick gets stuck. I can moving one way and then flick diagonally and it won't give me a 'Y' range or 'X' depending on my angle. I've tried lowering and increasing the deadzone but it makes no difference. I've even tried 'Unmapping' everything but the joystick and it still gets stuck.
Suggestions?
Thanks
Suggestions?
Thanks
