i very new to this community. i have made a custom keypad similar to the azeron (can be seen here) i can modify it if i can somehow get this plan to work.
the goal: genuine analog input with genuine mouse input on apex legends
according to this wiki of a list of games that support simultaneous input, apex has "Limited native support". not sure what it means but when i use a controller to run, and a mouse to aim, i get micro stutters.
as for my diy azeron, the joystick, is coded to be an 8 way directional pad which is not ideal (and i'd like to have analog support).
im willing to sacrifice a controller and use it (with it's joystick relocated to where it resides on my diy board) and having the pcb of the controller set internally under the palm rest (or elsewhere if it doesn't fit)
so the only part of a controller i want to use is a joystick. my custom pad + mouse will provide all other inputs. if i can fabricate this solution, can this powerful software make this at all possible?
so essentialy i need triple input (movement from a controller joystick, aim from a mouse, and all other controls from my diy keyboard)
thanks!
poblo
thanks!
poblo
