Lets say you hold W then shift to another profile which remaps the W to be something entirely different. The W key is ghosting and does not stop until you press it again. Is there a way to stop this?
How to stop sticky keys/ghost keys when shifting profiles?
Hi there,
May I ask you to specify steps more detailed.
Do I get you right:
Press and hold W button in the main layout ⇒ holding the W you select the shift layout, select the control to remap ⇒ the W appears in reWASD mappings and keeps beings selected for other controls even you release it?Don't worry! Be Happy!
For Star-LordOriginally Posted by Star-Lord View PostHello,
Do you remap controller or keyboard via reWASD?
According to the config you have, I assume that you switch to the green Shift using 5 keyboard key, and inside this shift W works as W. Then you press and hold W and switch back to the Main configuration, and in this case, the game gets W-down action but doesn't get W-up, and so the input gets stuck.
If you release W key before you press 5 to get back to the Main, there should not be any issue. Could you please check this way?
Okay, I see this may be the only solution. Strange how controller inputs don't become stuck if you switch profiles while holding down a button. I'm not requesting anything, but is it possible for there to be an action where all keys held down becomes reactivated when you switch profiles? Like it toggles all pressed keys off? Is it even plausible? Just wondering.Originally Posted by reWASDer View PostHey there!
Major changes to shift-system are in the works. We'll accommodate your suggestion as well.Originally Posted by Kabosun View Postis it possible for there to be an action where all keys held down becomes reactivated when you switch profiles? Like it toggles all pressed keys off? Is it even plausible?
