I just got into MACROs, as I have need of one for my PlayStation5, however I am not really sure how/if it is compatible with the DualSense controller. I am looking to use a simple MACRO setup to repeat a sequence of buttons for farming XP. Will this work with a PS5 controller? I haven’t downloaded the software yet, as I’m not sure if it will work. Do I simply input the buttons from the software or do I need basic coding skills to achieve this? Thank you in advance.
