I'm not sure if this is "how it's meant to work" or not, if so an option to toggle this behaviour would be wonderful.
Using the Autodetect (for the first time I will admit) and set to associate with Grim Dawn.exe with alt-tab as one input in the profile.
Running happily in-game, clicked to alt-tab back to the desktop and other running software, only to find when that trying to click alt-tab to get back to the game again that it was wasn't working, and found that reWASD had nothing applied even though the .exe is still running, click back to the game with the mouse on the taskbar game icon and the profile is applied again unless I click to alt-tab again and then the profile is disabled again.
I can see that this could be a very handy feature if it was possible to set a profile it dropped back to instead of having nothing applied, but (unless I'm missing something yet again
) it seems that as soon as the .exe isn't the focused window I'm currently losing all input on the controller as reWASD basically turns it off.
Is there any setting I've missed to keep the profile loaded all the time the .exe is running, regardless of whether it's the focused window or minimised?
