Hello, Is there any official Guideline for updating ReWASD?
The story is just the same as many others. I received the in software notice that a newer version is available and naturally just click on it and start the update, and then that's how things start going wrong.
The update was unsuccessful. ReWASD just keeps prompting "no permission to access the file location" or so on. any change permission level in windows or reinstallation was not helping.
After lengthy research and trial and error finally, one of the forum users use a method that uninstalls and reinstalls during all antivirus and security software is off, and that becomes the savior of all.
I would like to ask if any officially updating procedure is available that can save any problem from the future updates, since this problem is my second time, and last time I solved the problem by reinstall the entire system, and that wasn't funny.
Thank you
Best Regards,
Thank you
Best Regards,
