Bug: Azeron enable/disable overlays settings missing controller keys
  • Bug: Azeron enable/disable overlays settings missing controller keys
    This happens when going into settings -> desktop overlay -> enable/disable overlay.
    The list of controller keys to assign to any combination is missing a few keys (Keys 11 thru 13). The side 5-way stick is also not listed as a potential shortcut.
    Thank you for the report. The issue is confirmed, we will certainly fix it in the next release. Sorry for the inconvenience.
    Still, the D-Pad is here, in the list (below). The center click of the d-pad is missing though.
      Awesome and thanks for the super fast response! As a new owner it feels great to have such a responsive bugfix process.
      So just to clarify, there are 4 total missing items (11, 12, 13, d-pad click). But I think the joystick click should also be there now that I look at it.
        Stay tuned for updates. We really appreciate the assistance with fixing such glitches!
          The missed buttons are back to the list of available controls for the hotkeys (Slots and Overlay). Thanks again for the report.
          Please update to reWASD 5.8 to check the fix. You can also read about other novelties here.
