The main tray icon will reappear if you switch resolutions. The checkbox is unticked, but the icon appears. Checking it, applying, unchecking, and applying once more is required every time.
Tray Icon Issues
Originally Posted by Mobeeuz View PostThe main tray icon will reappear if you switch resolutions. The checkbox is unticked, but the icon appears. Checking it, applying, unchecking, and applying once more is required every time.
If I understand you correctly, the tray icon appears after you change the screen resolution on the system?
If so, I tried to reproduce your situation and my tray icon did not appear.
I suggest you to try to clear data. To do this, go to Preferences -> General Tab -> [Clear data] button. Then confirm the action and check if the issue persists.
Also check the version of reWASD you are using.
