[I'll start by saying I am using the 5.8.0.4512 build of reWASD for this. I just noticed there was a silent update to build 4546, which I just installed and will also test.]
The issue
I am having an issue with the game Warframe. I have a profile assigned to my Azeron keypad that has a main and a Shift 1 layer. When I alt-tab back into the game, the entire game will be frozen and will remain frozen until I use my assigned key to activate Shift 1. The game will then begin responding and rendering normally. I can then toggle back to the Main layer and continue to play as usual.
Things I have tried and other thoughts
Is there anything I can do to help gather more data? I am a pretty technical user and would be comfortable doing whatever diagnostic steps you suggest. Thanks!
EDIT: I fixed the mistyped version number above - I meant 5.8.0.4512 was the first build I tried and I then updated to 5.8.0.4546.
The issue
- I first thought this could have been an issue with autodetecting the EXE and loading, so I disabled all autodetection on all profiles and manually loaded the Warframe profile only. I have the same issue this way, which seems to indicate autodetect was not the issue.
- My profile is for this device only and has a single slot with a main and a Shift 1 layer only.
- This behavior seemed to start when I installed the new app version that supports the phone connection. I'm not 100% sure this was the time it started, but I am pretty sure this is true.
