Separarte key combos on Push and Release
  • Separarte key combos on Push and Release
    Is there a way to map a key combo to a button press, and another one when released? Can't seem to find it in software. These functions: https://imgur.com/a/1oPSZss
    For example, having Shift+2 on press, and Shift+3 on release. Worst case I can auto-hotkey it..but not sure if I'm just missing something since this is on the other button press "types".
    Also, is it possible to save a complex combo so that you don't have to redo them when moving them around?
    Thanks!
    The ability to map combos to Start and Release activators is not implemented at the moment. We are planning to add this thing for quite some time, still I do not have any ETA at the moment. Will be happy to let you know once it is released.
    Right now, you can open the combo, select the whole one (or a part) and Copy it, and then Paste to another combo. Also, you can Copy-Paste all the mappings you have on the button:
    The "combo library" (I think this is what you mean) is planned too, but again, no ETA
      Yes that's what I meant. Thanks for the answers will look forward to the new features!
        No problem, will certainly do our best!
          We have released reWASD 6.2 which allows you to set Combos to Start and Release activators. Please download the latest build from the official site or update from the app itself.
