I just wiped my hard drive and installed rewasd on a fresh OS, and now my keys seem to stick down while in game using my keyboard. For example: if I am running and I release the W after pressing A to strafe I continue to run forward for a second or two after release.
Performance issue
Hi.
Do you create a virtual controller using reWASD? If so, test if the virtual buttons/stick get stuck after applying the config on a gamepad tester.
Also, please send me the config you are using. Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles
I can see that your config uses only keyboard and mouse mapping. Maybe, it seems "sluggish" because the virtual controller works in this case.
You can try to set your mappings to act on behalf of your actual mouse and a keyboard.
Please enter reWASD preferences - virtual devices - select your actual devices for the mouse and keyboard.
