This where I'm at I'm using my ps5 controller with rewasd with ps remote play so i can use the gyro function all good but i can't change any of the thumbstick settings i can remap all other buttons if i unmap the thumbstick they stop working .
If i try and change the X Y axis of the thumbstick nothing happens the rotation setting works but not vertical axis range or horizontal axis range
