I'm hoping you'll understand my explanation
I've created a battlefield 2042 config with my virtual controller in reWASD.
I've unbound all the buttons and rebound them with mouse and keyboard and gyro and it's working amazingly in battlefield 2042.
I then created a sub config shift modifier which activated with the ADS left trigger which I've then changed the gyro sensitivities and that works great .
I've also created another shift modifier on the right trigger the fire button where I have changed the y axis to make it very sensitive on the giro so I can use it to combat anti recoil but I've noticed that when I pull in in the left trigger ADS shift modifier works but the fire button modifier isn't coming into use it's like reWASD can only use one shift modifier at a time and the first one what used stays and the second shift modifier the fire trigger doesn't override the first shift modifier if that's still in use
