While I was on trial of "Advance Mapping" feature ... I was a bit busy modifying Wii bluetooth adapter for use with PC and fixing one of my DS3 controllers ... and did not noticed my trial has expired
I have third party controller GameSir T4 Pro (https://www.gamesir.hk/collections/g...gamesir-t4-pro) ... its a Nintendo Switch PRO clone (with gyro) but has face button labels of X-Box controller. When connected to PC in switch mode, ReWASD detect it as Switch PRO (including its gyro function), which is great.
Here is annoying part: while I press A on controller ... ReWASD registers it as B ... aka physical location of button matches what is on Virtual Controller, its just the label does not.
If GameSir implemented so that when I press A ... ReWASD registers it as A ... then physical location of button will not match corresponding Virtual Controller ... BUT I know, this can be fix with "Advance Mapping" by swapping A with B and X with Y.
However, I am not sure if "Advance Mapping" can solve what I have now ... where I only need to change label of a button
Sorry if this is a bit confusing ... very hard to explain this in words
