I'm using reWASD for my razer Tartarus. Yes Razer has their own software, but personally I find it a bit lagging. Like at one point I thought that Tartarus was broken because some keys weren't being registered with precision. Until I tested it under linux using some guy's handmade software that emulates what razer's own software does, and there every key was working fine. So I suspected razer's software was buggy, and considering that development for it stopped(the old 2.0 version of Synapse) recently I've started using reWASD and I'm quite happy. But there is a feature I'm missing from that razer's software that I hope someone knows how to simulate it with reWASD.
Razer has it's own version of the Shift profile called keymaps. It works the same way, you can set a key to switch between keymaps...either as "while holding" or as "permanent" switch to that keymap. "While holding" does what Shift profiles do by default, while the permanent one I would adjust the stick left to go in to keymap8(for example) and in keymap8 I will adjust the same stick left to go back to keymap0 which is my default.
Basically when i press that button I'll go to keymap8 and until I press the same button again it won't go back to keymap0. Kind of like a toggle. Does anyone know how can I recreate this behavior with reWASD. I tried the "toggle" option but that appears to work as a "hold until pressed again", while I I want to just switch to Shift profile 4(for example) permanently until I call another button to jump to another Shift profile(in my case back to the default profile0).
